Use ACE Ethernet VLAN ID entries so that the filter looks for traffic on specific VLANs. You can insert an ACE Ethernet VLAN ID only for ACL VLAN types.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select Eth.
  8. Select the Vlan Id tab.
  9. Select Insert.
  10. Specify the operation type.
  11. Enter the VLAN ID or select from a list.
  12. Select Insert.
VLAN ID Field Descriptions
Use the data in the following table to use the Vlan Id tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq parameter specifies an operator for a field match condition: equal to.
VlanId
Specifies the VLAN ID on which to perform a match.
OperMask
Specifies the mask value for a VLAN attribute.
